Leif
I've recently refinished an Ercol plank dining table, and a round coffee table, both with elm tops, using Danish Oil (3 coats, the first coloured on the top) and Briwax, and I am pleased with how they turned out. The plank has a lovely figure on the top, where the knots are.
Anyway, I have some questions.
What do people recommend as the best way to strip the original finish? I used sandpaper, grade 80 to remove the top layer of finish, working down to grade 400 before oiling. But I would like a less abrasive method if possible. Nitromors stinks and is expensive. The eco stuff did not work well on what I assume was nitrocellulose. There is a company that sells there own strippers, I think Kling Strip is one, and they work well on painted architraves. I've not tried them on Ercol finishes i.e. nitrocellulose and acrylic.
I love Ercol furniture as it is in my view good solid wood, with nice designs. The darker stuff is cheap at auction, but can it be stripped and lightened with oxalic acid, or will it always look like dark furniture stripped? There is a chap on ebay who sells refinished Ercol, but you can always tell the ones that were originally dark. I like a so-called medium oak finish i.e. dark enough to highlight grain.
Modern stuff has an acrylic finish. Can this be repaired? Maybe wax filler and polish? I've seen shelves on Ebay, but stripping the insides does not appeal.
Can beech be stained? I tried staining the beech frame of the plank table. First I tried a solvent based stain, but it was patchy. I removed it and tried a coloured Danish Oil, but again it was patchy. The stain did not highlight the grain, and some areas came out dark and ugly. I wasn't keen in the result. So I removed it and tried natural DO, which looks nice.
The round coffee table had a weird top. It is made from planks, with a nice concentric ellipse grain pattern. But it was very uneven i.e. not flat. Different growth rings were at different heights. How do they do that? Or is it shrinkage? The table must have been at least 40 years old.
And finally ... phew ... were I to buy an Ercol chest of drawers, or a cabinet, would it be hard to strip the insides? I cannot imagine sanding the finish off. Each table took a day to strip, but a cupboard seems like a nightmare.
