andrewm
My project for next weekend is to lay a new tongue and groove hardwood floor in the hall. To allow for a recessed mat one section will not go right to the door and what is more the end will be angled. I want to put an additional strip across this end and since the rest of the boards are tongue and groove was going to put a tongue on the angled end to attach a narrow board to.
This means that I am going to have to cut and angled tongue on the end grain and probably put a corresponding groove in a narrow board. Because of the length of the boards I don’t think this is possible on the ‘Rat.
Now, the boards are 20mm thick so too thick for a standard tongue and groove router set and besides the groove is 6mm which seems to be a non-standard size. As I see it I can cut the tongue using a bearing guided rebate cutter and the groove using a bearing guided slot cutter although I may need to change the beating to get the right depth. If I butt a piece of scrap against the board I can avoid breakout.
As far as I can see this should work but is there anything that I have forgotten? Or, am I trying to make things to complicated and should I forget matching the tongue and grove and just use biscuits.
Any advice appreciated.
Andrew
Andrew
