Jester129
'Not for design use.'
LOVE IT!
LOVE IT!
I do that too, after using my Fluke. And then there are [Martindale] ‘Proving Units’ to consider.I normally use a DVM to check the wiring is dead, and I use insulated tools etc. but I don't trust anything, especially myself, so the last thing I do before I actually start working is to very quickly flick my finger across the copper.
Not considered suitable by the industry “voluntary regulatory bodies” such as the NICEIC, NAPIT, or the IET.Not considered suitable by who Paul?
Approved by who?
Avo 7 to modern DMM's, all meet the need if used appropriately.
I try to remember to use the back of the hand for this test as anything on the front is likely to make the hand muscles contract and therefore grip the cable. Ditto check the neutral too as that's the one that catches you out when it has gone live.I normally use a DVM to check the wiring is dead, and I use insulated tools etc. but I don't trust anything, especially myself, so the last thing I do before I actually start working is to very quickly flick my finger across the copper.
lol, modern times! sigh!!'Not for design use.'
LOVE IT!
No current regulations then?Not considered suitable by the industry “voluntary regulatory bodies” such as the NICEIC, NAPIT, or the IET.
Not approved bu Her Majesties Health and Safety Executive.
No multimeter meets the need because it has the ability to be set incorrectly and then it would not indicate the presence or absence of voltage.
Look at the HSE website for the details.
What I think NBP means is that multimeters are not suitable for proving dead, according to the quoted bodies.No current regulations then?
No specific current HSE directive Paul?
"Go look it up", sounds like you're quoting a doubting Thomas?
Were it so 'unsafe' I doubt they would be on sale in the UK.
Large trim, but I agree. You and me both.I'm a bit paranoid. But for logical reason.
Yes, as with many H&S type regs, you can do what you like in your own home - multimeter, light bulb with two wires, finger...IMHO a lecky is a different beast to a home user checking the home system?
Used as per instructions, a DMM is 'safe'
A sparky at work has to abide by the rules, and they consider a multimeter unsuitable for proving dead. Fine for diagnostic work, though, as long as it’s rated for the area you’re probing - Cat I-IV ratings.
That is absolutely correct, you must use the correct tester and confirm that tester is functioning first by using the proving unit, a multimeter or multifunction tester is classed as an instrument because it will have a calibration certificate. Things have really changed because I can remember when we just used a bulb tester or an apprentice. The procedure used now is to first prove live, then isolate and prove dead so as you confirm it is your action that resulted in the isolation. Reason being we used to just isolate and prove dead but I can remember a case where an isolation was performed and during the work one of the electricians got a kick and some burns as the power came back on. On investigation they had correctly isolated as per drawing but the drawing did not reflect the current system.What I think NBP means is that multimeters are not suitable for proving dead, according to the quoted bodies.
You’re certainly persistent..."They"?
Again, the mysterious they say...
Way, way back in time I was very junior and working on a BBC transmitter and working inside the guts of it standing on a ladder. I had very little clearance for my head where I was working. Unbeknownst to me, on one side the casing had, due to a fault plus poor DC isolation by me and my senior engineer before fault finding, become attached to the HT...a few KV. My ear touched. My head rebounded and hit the dead casing opposite which made me recoil to...touch the live again. I literally rattled my way downwards which probably saved my life. I kid you not.Being a high voltage vehicle technician in my day job, when working inside the battery we have to 'gear up', insulated boots, 2 layers of gloves (one cotton, one insulated), overalls with a fine mesh inside to act as a faraday cage in the event of contact and a face shield. Of course these vehicles use dc and inside the battery there are no safety devices.
While training we were explicitly told that if we get a shock we should attend hospital as there is a risk of internal burns which in turn can cause an increased release of myglobin and platelets into the blood which can essentially poison you. This might not happen straight away but could be weeks later, they can test you blood and treat you accordingly.
Matt
