Nic.Watson
Hi all,
After extensive googling, I'm struggling to find the answer and hoping one of you guys may be able to help.
I've got an Electra Beckum HC260C and almost every time I use it, I blow at least one fuse in the plug, sometimes 2-3 in trying to get it started. It's in my workshop at the end of the garden which has a 3-core, 6mm2 armoured cable run of about 60m to power it and I'm assuming this may have something to do with it. Whenever it starts up, it starts spinning but then dies out after a few seconds as the fuse blows. It feels like it's to do with the fact that there's a significant power draw on startup and then when the motor starts spinning, and acts like a generator, it surges and that's what causes the fuse to blow. It does make the lights etc. in the workshop pulse with the rotations as it powers down so it's definitely got some weight behind it.
Do I need to do something to smooth out the power, if so, what? Or is it something where if I increased the size of the fuse from 13A slightly it would stop the issue as long as I don't exceed the MCB?
Thanks for any help/advice.
Nic
Nic
