woodbloke
As an excuse to get out into a cold 'shop tonite here's how I do my projection board for the Eclipse gauge. This is the stuff I need:
Draw a line with the protractor at the desired angle onto the surface of the mdf, in this case 27deg:
Set the sliding bevel to exactly this angle and cramp firmly to the board:
Offer up the plane blade under the bevel and then locate the honing guide onto the blade and tighten:
Cramp the blade and guide into one half of the new projection board:
and then glue on the second bit so it makes contact with the edge of the plane blade:
so that the finished job is thus:
I used the hot glue gun as Gidon thought...13 minutes, but I had to take the pics with the D60...Paul :lol: - Rob
