I should have made the point before that the woodworking industry tends to burn only solid waste - dust is collected for use in producing chipboard/MDF or pressed into pellets for burning. Even Felder have a briquetting machine which goes onto their larger extractors, mind yoy they cost about £10k!
The other point I should have made is that commercial wood heating units such as the Talbott have an afterburner option where the flue gas is monitored and a secondary gas burner is used to fully combust any materials still in the exhaust. This reduces smoke production considerably and is a legal requirement in smokeless zones. The only approach one can take with a stove is to utilise a fire brick lining and a stove with an "air injector" design such as the Relax design sold by The Hot Spot where a "dampable" air tube extends into the base of the fire to promote higher combustion temperatures. I used to have an R6 and it worked quite well, although loading with sawdust could only be indertaken at the time I started it up for the reasons mentioned above.
Scrit
Scrit
