Dissolve
Hello,
I currently have the cheap Axminster RDC 100 vacuum extractor and as I'm spending more and more time in there these days I need to take my dust extraction more seriously.
I've been looking at the numatic range, particularly as I have an outdoor appears workshop around the size of a garage I could direct my exhaust air outside through a port in the wall.
I'm looking to spend £350 maximum and space is the only other real constraint, I'd like it to fit under the bench.
I use a dust mask when I'm sanding but generally take it off half an hour afterwards, I have asthma so it's becoming more of a concern.
I use a bandsaw with a 100mm port, triton routers that use a 32mm numatic size hose with a stepped adapter. Other tools can be adapted to fit but I could do with cutting one based on these factors.
Can anyone recommend me a vacuum extractor they've found good value for money?
