Dust extraction Multico Th1 or Th3 opinions
jackal
Wallybois Woodworking on YouTube
10 Jan 2011
France...limousin
I now have my Multico TH1 which after a good degrease and lube runs nice.
First test thicknessing a piece of Oak there was a lot of planings thrown backwards even though it was connected to a 3hp extractor.
Have you experienced this? Thanks🥺
A few questions: What is the extractor capable of extracting in cfm or M3/hr? What size ducting do you have? Is it a straight run or circuit?
Hi, the extractor is 3900 M3/hr and Have 150mm down to 110mmat the machine. The other gates are closed otherwise it is a circuit.
thanks PAC1
thanks PAC1
That is probably not enough suck, you need to check but I would have thought a machine like that would need 1000cfm or 6000M3/hr. Most thicknessers need at least 1000cfm
I made a little mod to the hood which has helped a lot. Just uploaded a Video on it here
Just watched the video, my hood actually has a sheet metal deflector curve there which I think was original but it was brazed in place and the braze had broken in a couple of spots so I welded it up properly.
I really like the videos by the way!
Thanks Trevanion, that makes sense, i wouldn't be surprised mine was the same and it just got lost. The existing deflector is brazed. I think ill weld that hood and add a piece of round sheet steel. 🤔
