Dust extraction Katsu Plunge base
Rorschach
Guest
6 Jan 2016
Devon
Dust extraction on the trimmer base works great but I don't have it on the plunge base and my home made rig was woeful. Does anyone know if there is a port that can be added? I assume the Makita one would fit but what model would I need to order?
galleywood":1knsmyaz said:
I have that Makita dust port on my Katsu - it does not work very well though.
I doubted any plunge base extraction would work as well as the trimmer base, does it at least help though? I have made a right old mess so far and anything has got to be better than nothing.
If it helps i used that on my makita router the other day with plunge base for the first time. Once id remembered to empty my vac bag :oops: it worked well. No real mdf dust (visible at least) in the air. Some left in cut but turned off router and retraced cut and vac got that too.
That's very helpful thank you.
The makita dust extraction nozzle from amazon (£4) seems to fit ok but will need a little bit filing off one of the clips, otherwise it looks good. How effective it will be compared to the trimmer base extraction remains to be seen, likely not as good, but better than nothing.
Tested this morning, minor modification needed to make it fit, added a zip tie for extra support too.
Works fine. As expected the extraction is nowhere near as good as the trimmer base but I would say it got at least 90% of the mess, especially the finer dust. Efficiency depends a lot of how you cut too, one way sprays the dust away from the hose so that is obviously not helpful, cutting in the other direction though aims it toward the hose and then it was really effective.
Well worth a few quid and a nice addition. Will be especially helpful when using the track attachment for drilling etc.
Meant to reply to this thread over the weekend then forgot. Was using the same set up with a sled to flatten the top of a workbench. Raised off the worksurface the vac got turned off because it had no effect (and it's bleedin' noisy that lidl vac tbh ). I'd expected as much but still on a big learning curve with routers. Wondered vaguely about searching through my plumbing bits/surplus to knock a solution together. Thought about tacking a skirt to the bottom of the sled and some bends and pipes so it sits at the back/bottom of the sled. In the end I never got round to it because... well... But I may well attempt it as I'd like to keep the flattening sled jig set up. I'll post pics if I do.
In other news even though I'm certain I did the bit up well (3000 rpm certain!) at some point it 'dropped' and now my bench will be a little thinner that it was going to be... :|
I'm still not sure how it occurred. Not the end of the world but I walked away fairly rapidly before I set fire to the shed and killed everyone in my street. Now I'm older I'm much wiser and calmer. So that's why I never made the news. 8-[
I've no idea how I managed this. Completely baffled. The sled is not sagging in the middle. The guides are solid. Oak battens (true) in fact that I've scrounged screwed to the edge faces of the bench. Square and level. I was really careful setting up the guide battens, the jig, everything really.
I'm baffled.
Any insider info?
I'd appreciate any help from the Bigger Boys.
Cheers now
Chris
I'm baffled.
Any insider info?
Cheers now
Chris
If the bit dropped in the collet then it won't be anything other than it not being tight.
If the bit was still firmly in the collet, then if you are using the plunge base it could be the depth stop screw slacked off...
Sent from my Redmi Note 5 using Tapatalk
Thanks Bodgers. Much appreciated. Was wondering if I could be missing something with my inexperience. Appears not though I'm still slightly bemused by it. The margins must have been extreme!
It must be the collet not being tight enough. I read the other day in Alan Holtman's Trend 'Complete Routing' about not over-tightening. Perhaps I was a little to easy on the hand tight then half a spanner turn advice! Can't see it being the collet or the Wealden bit which leaves user error.
It's clearly worked out a few mm when I just went out too check. But I can't budge it by hand it's not that loose. Will hit the spanners with a club hammer next time. (Joke! :D )
You can lock off the depth stop screw on that Makita model so I don't think it was that.
Not the end of the world, just a tedious job. The bit is a longer shanked 12mm straight flute to accommodate the sled height. Bit leery of cutting much more than 3mm in one pass. Will have to do the other half of the bench to height then redo it all again to finish. It's thick enough to take it but a 12mm bit on a 6 foot by 2 1/2 odd foot surface is a bit jarry! Still have to sand it after. :roll:
I looked at the dedicated bits for flattening stock but they were £30+ and with Christmas due in a minute, could not justify it however I kidded myself.
Think I'll do it with a plane next time. Thought I could probably get it flatter this first time with a sled.
Thanks again Bodgers.
Appreciate you taking the time fella,
Chris
& therein, I suspect, lies the problem. How stiff the nut is doesn't matter, the collet must grip the shaft before the final tighten.
