Just my tuppence worth, but I'd suspect that while using old, second hand motors to make home made extractors, you'd want to be especially careful to avoid any chance of the fine wood dust "leaking" through to being in contact with any part of the motor or electrical contacts.
It may seem perfectly obvious on paper like that, but you'd be surprised how many folks don't realise that a good suspension of wood dust in air + electrical spark = full on explosion of the potentially terminal kind. There's been a fair number of accidents over the years caused by it.
Be safe fellas.
Also, My dual motor Numatic extractor is 750m3/h and it's pitifully under powered when using its 100mm hose. Something I wish I'd known earlier - it can't handle careful cuts on my bandsaw without using the smaller vacuum cleaner sized nozzle mounted directly under the table insert. A P/T trying to use that thing would choke in seconds.
Nic.
