StevieB
The dust in my workshop/cellar is starting to get annoying, and being based in a cellar I cannot simply open a door or window and sweep/tip it out! So a serious think about decent dust extraction is required. I am in the fortunate position that the whole cellar is going to be turned into proper 'rooms' (ie plasterboarded and ceilinged etc) and I currently have ceiling voids where the rafters/floor joists are so have a bit of space to play with. The cellar is already cramped however so not that much space.
First port of call - a search of the forums. Hmm, over 800 posts on dust extraction. Next is google - loads of industrial sites but none that seem to give me a basic overview of what options are available to me. So hopefully dear members you can point me in the direction of a good site, good book or offer some sage advice on the following:
The main machines I have are a tablesaw (kity 419) a bandsaw (EB BAS250) a jointer (Axminster CT150) and a thicknesser (Axminster 330). The jointer and thicknesser produce large chippings and the jointer I am happy to let them fall into a bucket. The other three I would like extraction fitted to. The position of the round the shop is fairly fixed due to an odd shaped cellar and space constraints so I am wondering if running flexible hose from each to a static extractor is feasible? Axminster do a 1hp extractor (AWEDE2) and 100mm fittings kit with blast gates and flexible hose. I estimate probably max 10 meters hose required with a blast gate before each machine and a couple of T pieces should be all that is required. My questions however are is a 1hp extractor enough for that length of 100mm hose? Am I likely to have future problems putting hose above a plasterboard ceiling (ignore the obvious access issues, but do they pierce often with chippings etc and need frequent replacement?) and is flexible hose a good option compared to rigid plastic - either the 63mm kit from Axminster or 4" soil pipe/B&Q drain pipe etc? Finally is 100mm likely to be too big a diameter - is smaller better with a cowl to the 100mm outlet on the machines or should it be 100mm all the way?
I have a small portable shop vac for hand held power tools so its only the big machines I would like this extraction system fitted to. Or am I going way too complicated with fixed ducting/flexible pipe and should consider something simpler? Due to space limitation round the shop however I do not think a big extractor like the Axminster AWEDE2 is feasible to be tugged round and fitted to each machine as it is used.
As always price is an issue, but would rather do it once properly than have to faff and replace because I still have dust everywhere. Main tool used is the tablesaw and its coarse dust from that rather than jointer chippings I would like dealt with most efficiently.
I am trawling through the posts I found through the search of the forums, but pointers or advice not already covered gratefully received!
Steve.
Steve.
