Bigfoot1980
Hi all,
I know there is a huge amount of information on the forum regarding dust extraction but I think there is so much I am going round in circles and not coming up with a solution so wonder if you could advise on my own situation.
I work in my garage which is approximately 16m2. I have a Titan table saw with 60mm connection on the back and 32mm on the crown guard. I also have a router, circular saw and orbital sander which are all around 32mm. I have been using my Henry on all of these which seems to work fine for the sander but not so great with anything else. When using the table saw most of the sawdust ends up on the floor.
I do wear a mask when using the equipment but I think there is a lot of dust floating around in the air afterwards which I am concerned about. I was doing some work out there yesterday and have a bit of a cough today which I think is from the dust so I would like to find a better way of keeping the air clean.
I am happy to move a dust extractor around the garage to wherever I need it and won't be installing pipework and blast gates etc. so would just like to know what direction I should be heading for cost effective ways of reducing the dust.
Would the Henry be sufficient if I set-up a cyclone with a separate bucket or should I look at replacing / adding to the Henry with something like the Record DX1000? Is the Record much different from the Henry?
Also, would it be beneficial to get an air scrubber as well to put on to clear the air after I have stopped working?
My initial thoughts were that I get the DX1000 to use on all of the machines although I won't be needing the 100mm connection as have nothing that size so will reduce down and then an air scrubber as well. I may be heading completely in the wrong direction so any assistance would be appreciated.
