Dust Extraction, Adaptor Question
custard
20 Aug 2008
Hampshire
Another tedious dust extraction question, sorry about that.
I'm trying to connect a Festool 36mm O/D hose into a router based jig that basically uses the imperial 2 1/2" O/D system. Axminster have a 63mm dust system which I assume is the 2 1/2" system under a different name? But in any event they don't seem to have an adapter that would allow the Festool 36mm hose to plug into it. Any suggestions?
Should work. 63mm is a gnat's nipple under 2 1/2" so at worst you may need a wrap of electrical tape around the adapter to take up any slack when fitting into the jig.
Trend do an adapter for their router table and with a bit of electrical tape to create a really tight fit it works well with a Festool 36mm hose.
I use the a standard size hose system but have to connect various tools into it so I ended up making my own adapter rings out of MDF. Put a slight tapper on and you should be good.
I can't understand why there is no industry standard for these things. Even within specific manufacturers ranges there are incompatibilities.
Ah I know what you mean, it's very frustrating. I know there needs to be difference sizes but honestly there are so many. I think I've got about 6 different adapter for about 8 machines!
