mqbernardo
OK, thanks for reading and sorry for coming at this again. after some thought on an air filtration system (now settled) and after reading through some of Bill Pentz´s notes i started thinking about my new dust collection system (my old one is just too underpowered).
as you all know (and i´ve just recently discovered) the smaller the dust particles are, the worst offenders they are to your health/lungs membranes, so you should go with the smaller particle size filters you could find/afford on your DC system, right? of course, there are constrains to how small you can go (even if only financial ones) and the filters - if the pore size is small enough and reduce the net area IIRC - will end up stealing some suction from your dust collection and should clog faster (i´m just thinking out loud, please correct me if needed).
so i´m asking for advice on a sensible particle size for a dust collection system. I will connect it to my drum sander unit, which is a small Jet 10-20 and will be using it for the last stages of thicknessing guitar plates (i already talked about that on another thread, sorry for repeating myself), so i won´t be using any MDF, nor will i be making huge amounts of dust (the woods will mainly be spruce and indian rosewood BTW). i´ve seen 0.2 micron filters, but i don´t know if i must go that low. In the beginning i was thinking about the axminster UB-801F which claims 5 microns particle filtration, then i thought about adding the 1 micron canister filter, but then i started hearing that one should use sub-micron filters (which to my knowledge axminster does not have)... this quickly gets very confusing. any help appreciated!
thanks in advance,
Miguel
portugal.
edit: edited for typos.
thanks in advance,
Miguel
portugal.
