johnnyb
I've had a xl700 domino for a while and noticed that when I set the fence angle on the detent(at90) it's drooping. So say I'm joining a door the end grain mortice and the long grain mortice are pointing in different directions! The fence angle isn't adjustable on the detent. I've made a strip of wood that I use by loosening the angle lock putting the base on a parallel surface then using the parallel piece of wood to make the fence level then lock the fence ignoring the detente. This then works fine.
Should this be happening, has it happened to anyone else? It's a pain on what should be a turnkey solution.
Send it back?
Send it back?
