PearlyKing
I am replacing a rotted gate gate post. It is 250mm square and 2100mm high,above ground, 2800mm overall,. I am trying to work out how to drill the hinge bolt holes keeping them straight and parallel to the ground.
I don't want to drill them before I install the post as I don't believe that I can position it accurately enough to be level with the other gate post hinges.
One thought was to screw on a pipe holding base/wall flange as per attached photos, with the grub screw removed; it is 30mm deep, which I am hoping is enough to keep the drill bit straight. Any criticism or other thoughts and suggestions very welcome.
