Doug B
Shy Tot
Ever since seeing a comercial drill tidy a few months back & thinking what a handy thing a small platform attached to the pillar drill would be, it has been on my to do list, so in between waiting for glue to set & stain to dry today, I`ve finally got round to making one.
I started with the arm that goes round the pillar, marking out the dimensions on a piece of 1" thick Oak.
This was rough cut out on the bandsaw & with a jigsaw.
After which it was cleaned up, edges rounded over, bolts drilled for & a hole drilled for the tray peg, it was then fitted to the pillar.
Next I turned the tray at the lathe from an off cut of Oak worktop, scoring lines in the surface to aid drilling later.
A Beech peg was then turn to match the hole in the arm.
Finally after drilling holes for the peg & the drill bits it was time to assemble.
It will be good having bits to hand at the pillar drill & a home for the ever elusive chuck key
Cheers.
Cheers.
