clive griffiths
I am looking to buy a new drill press , possibly a scheppack around £200 or the axminster around£400, need something with enough power to drill up to 40mm forstner etc.
I had a look on the all ads and there is a nice looking fobco just the size I would be looking for, only problem it is up in wilmslow, will have a good think on that one.
If you mean drill twist bits you will not go far wrong with Dormer. One of the very best and can be used on wood or ferrous material. Fisch are good for wood twist drill bits, Augers and Forstner type bits.Back again, Anyone with info on optimum drills.
Thanks.
Hi Chippy - Optimum is a brand name.Back again, Anyone with info on optimum drills.
Thanks.
I can't explain the difference in price. However, one UK vendor I saw (not Zoro Tools UK), had a picture of a B17 Pro in the webpage for the D17 Pro. The B series drills do not include the digital speed control and could be about £100 less expensive than the D series. I would ask the vendor to confirm the model before ordering.
Very little. A 1ph .5hp motor will be cheap enough and a power switch is £5 from ebay if you don't need to match. If its dual phase a VFD would be good for a pillar drill for speed controlmeddings three phase to single, how much work is there.
Thanks.
Just been looking at the reviews and does not look to good (Icould be wrong)
