Drill guides and forsteners
milkman
14 Sep 2006
Hackney, London
Not having a pillar drill I bunged a forstener in a highish torque drill and used a wolfcraft guide to drill.
Blimey was that hard work!?
Question is why? I used the drill set to slow, slow, slow so the bit wouldn't choke on the waste but even so it took all my weight to drill the holes.
Help appreciated. I won't be getting a pillar drill anytime soon but would like to be able to use these kind of bits on things.
Was it a cheap imported bit or a decent make, what does it cut like hand? and what diameter and what wood were you trying to drill
Jason
I tried the same and I gave up on the idea and bought a £30 pillar drill from B&Q. You can also get drill presses that will hold an ordinary drill, worth keeping an eye open in the Lidl / Aldi / Nettos of this world.
I do know what you mean. I have the set of bits from Axminster, which in a drill press are fairly potent. In a cheapy drill guide it's much harder.
The thing is you may not realise is just how much leverage and hence force you get on a drill press, the torque of a slower running motor and the fact that you will get very little friction on the sides of the bit that keeping it straight affords.
Aidan
I guess you were drilling into normal grain rather than into end grain ? In end grain you make more progress with sawtooth bits rather than plain forstner bits......
Cheers, Paul. :D
