Drill Chuck Sizes
Terry Smart
Chestnut Products
8 Jun 2004
UK
Hi
Sorry if I'm being lazy asking the question, I've had a quick look around but can't get a 'simple' answer...
Is there a 'standard' maximum size for what will fit into a drill chuck?
Thanks in advance
Terry
Hi Terry - normal corded/cordless drill chucks are 10mm or 13mm,pillar drills are often 13mm or 16mm - sizes being the largest diameter shank they can take.
Andrew
Thanks Andrew, and for answering the question in the way I should have asked it!
You can tell I'm not mechanically minded!
Thanks again
I think Andrew has just about nailed it for the majority of 'standard equipment'
The bias being towards the lower figure in each case.
Smaller drill/drivers and craft pillar may only be 6mm.
