Drill Bits For Pillar Drills
Stanleymonkey
15 Jun 2014
South West London
Hi all
Is there a recommended bit for use in pillar drills?
I have a cheap drill stand (might be the problem) but I've noticed with regular all round twist drill bits that they can kick to the side - which is really annoying if I'm trying to be accurate!
Can anyone help?
If it's for wood I use and recommend Brad Point bits.
attachment.php
You could always take a tip from metalworking and start first with a centre-drill.
They are very stiff and will not flex.
http://www.axminster.co.uk/centre-drills-bs-set-12
Then follow-up with a normal twist drill.
Otherwise try using bullet-point drills like the DeWalt Extreme-2 drill bits which effectively combine a pilot and main drill bit into one. These work well in most materials including wood end-grain. Not cheap though but a favourite of pen-turners.
http://www.screwfix.com/p/dewalt-12...RIXodDizNiXQ-7LJrHzzH67BB_noYUTM0GD6pZ4rw_wcB
HTH
Jon
The "standard" practice is using a sharp center punch on the mark, then a small diameter drill for a starter hole, or even a pilot hole.
For more accurate marking when you are working on metal, paint the surface with an indelible marker, then mark the spot to be drilled by scribbing a cross on the painted surface with a steel point. This will make it much easier to see the exact spot where to punch.
Any twist drill will wander somewhat if you don't mark the spot with a center punch to start with; the smaller diameter ones wander because they tend to flex, the larger diameter ones wander because the web off the drill is too wide to start an accurate hole. A large diameter drill may need a starter hole even if a center punch was used. I usually drill starter/pilot holes for any hole over 3mm final diameter.
As I have a rather small and low-powered bench drill press, when drilling metal, after center punching I usually start with a 3mm drill (unless the hole is smaller than that, of course), then up from there in 2mm increments up to 0.5mm under the final size, then finish to the final diameter. This has the advantage of reducing the stress and wear on the drill press and giving a cleaner hole. Of course, the successive drillings must be in as perfect indexed to the spindle as possible so the hole stays true, and ideally the part to be drilled should be well clamped to the DP table.
The downside with this method is, if you go from a very small sized, short drill bit up to a rather longish one, and the spindle on your DP has a shortish stroke (mine is just 50mm) - say, starting with a 3mm drill and going up to 10mm, for example - you may have to adjust the position of the table to get enough heigh for the longer drill. This will need some very careful repositionning, so a good beforehand preparation is needed. But it can be done if you are careful enough.
Edit: almost forgot - when drilling hard metals use some form of lubrication, otherwise too much heat will be generated.
All the advice so far is great but I wonder if the root of your problem is that you are using an electric drill in a drill stand? Several problems with this setup: it is likely that the drill bit will end up significantly out of the vertical, even ina good quality stand. The drill itself, in order to develop enough torque, will be running very fast. The bearings on an elecric drill - even a good one-are not very accurate and so the chuck will always wobble slightly under lateral pressure. All these factors will make it very hard to control the drill bit. Brad points are very helpful, sharpness is critical, but long bits (esecially large diameter spade bits) make the problem worse, Once you have used a proper pillar drill, you can tell the difference. It is an investment I should have made many years ago!
