I wonder if its a multiple of the diameter, I am sure someone on here will know?
Mike
Found this on Wiki:
Screw-machine-length drill[edit]
The shortest standard-length drills (that is, lowest length-to-diameter ratio) are screw-machine-length drills (sometimes abbreviated S/M). They get their name from their most common application: use in screw machines. Given the industrial nature of most demand for screw-machine-length drills, they are generally sold only by metalworking supply businesses (not in hardware stores or home centers).
Jobber-length drill[edit]
Jobber-length drills are the most commonly found type of drill. The length of the flutes is between 9 and 14 times the diameter of the drill, depending on the drill size. So a 1⁄2 in (12.7 mm) diameter drill will be able to drill a hole 4 1⁄2 in (114.3 mm) deep, since it is 9 times the diameter in length. A 1⁄8 in (3.2 mm) diameter drill can drill a hole 1 5⁄8 in (41.3 mm) deep, since it is 13 times the diameter in flute length.[2]
Aircraft-length drill[edit]
Extended-reach or long-series drills are commonly called aircraft-length from their original use in manufacturing riveted aluminum aircraft. For bits thicker than a minimum size such as 1/8 inch, they are available in fixed lengths such as 6, 8, 12, or 18 inches rather than the progressive lengths of jobber drills.
#-o (hammer)
Mike
