--- Litte 'Aside' ---]
Mike - if its anything like mine.. the vibes are bordering on horrendous. I've had the wheel off. calipered it, it's round. I changed it out for a new wheel.. same story. Cant say whether there's 'heavy spots' within it, causing a 'balance' problem.. I've marked it with a black marker, 'freehanded it, and it settles in a different spot each time, so I don't think its out of balance density-wise. ... but its dancing about like Hughie Green on acid. Its on a stand designed for the job, anchored into the concrete floor of the garage. To be honest, I'm a bit hacked off about the whole thing.. damn machine was £68. But I thought the problem was unique to me. Hearing what you have to say now makes me think otherwise. 1 is a 'one-off', two is a habit. I did wonder whether the difference in wheel thicknesses from end-to end, as the machine comes with, had anything to do with its problem... Looking at it, the wheels are equidistant from centre, and if there are two different weights of wheel at opposing ends of a hig-revs rotating shaft, I'm thinking there has to be some sort of gyroscopic effect taking place.... perhaps some of the real 'engineers' here ( as opposed to a spanner monkey such as I am ) may have some thoughts ? ... Chas, this is something I'd imagine you're pretty clued up on ... or any of the other lads with the right knowledge or experience... any input would be helpful ! This warrants further investigation, Mike .... If yours is anything like mine.. its bordering on being unuseable. :!:
