J_SAMa
I had relative success with flattening and India stone on regular wet and dry sandpaper. Took long but it did work. Not so much luck with a Crystolon though... The fine side was alright but it seems that the coarse side was chewing up the sandpaper faster than the sandpaper was flattening it. Tried flattening it against the India only to have the India clogged :evil: Had to redress the India after that...
Now I could just try and use it without flattening but it's sort of clogged too so I have to at least dress it somehow... The only solution I can think of is aluminum oxide grinding sticks in a drill. Probably won't get the thing flat but at least will get it to cut. Am I nuts or has someone else tried doing this already?
While I'm at it, is it normal to get a lot of dust coming off of a fine crystolon? I get more grits coming off of it than I do with a waterstone...
Thank you,
Sam
Thank you,
Sam
