AES
Agree with Lons' point about using a "Dremel" variable chuck, rather than "just" collets (my Workzone came with just 3 sizes of collet, no chuck).
But if you're careful choosing your sanding, drilling, cutting, etc, accessories, you can limit yourself to a shaft size/s which fits your chosen collet (I'm on 3.2mm dia as a more or less standard). And using either the drill directly with a collet or via a flexi shaft with a collet does lead to a slightly smaller "package" in the hand for careful work - a bit easier than with using a chuck.
But I agree 100% with Lons - if you're unable/unwilling to "standardise" on a shaft dia for your accessories, changing collets is a bit of a ***, and a chuck gives you much more flexibility (sorry, no pun intended)!
Re whatnot's point above about using a "normal" drill with a "big" flexi shaft being too noisy, personally I don't find the overall noise of the "normal" electric drill compared to that of the "Dremel" drill much different in "loudness" - different tone yes, but overall, about the same to me - and anyway, the shop vac I use more than drowns either/both of them out anyway!
But I notice you're forced to work indoors (or outdoors when it's fine). Under those conditions you may need to be more careful - neighbours when outside, family when inside. I think that the noise of the "normal" electric drill may well be more "penetrating" over a wider distance than the "Dremel" type drill. But dunno for certain.
