Drawers
SketchUp Guru
12 Apr 2005
Rochester, MN USA
I woke up this morning at about 4 am. Too early to be banging around in my shop (which needs to be banged around in) so I had to find a quiet way to amuse myself. This is what I ended up with. It's Chris Gochnour's 12-drawer Shaker-style Wall Cabinet.
If you want to see a larger version, click on the picture.
Another project for my real shop when I get time.
I used this cabinet to demonstrate a method of drawing dovetails which you can see on the blog if you're interested.
Dave,
This is a test right? We are supposed to guess whether this was really done the old-fashioned way or whether you have just invented a new style for SU?
Either way, It will be great practice for hand cut dovetails. By the time you are finished you can join Rob Cosman on the show circuit!
Hi Chris,
If you had seen some of my old-fashioned drawings you'd have no problem deciding how I did this image. They only let me have wax crayons to draw with the old-fashioned way. And only if I promise not to eat them. :lol:
Actually I thought about creating a style with the graph paper but I decided it was too much work to create the overlay image of the graph paper. I used a sketchy line style to export the various images and put them over the graph paper in Paint.NET.
As to cutting the dovetails, you're probably right. But I was thinking about using the Router Boss to do them for the practice with it.
Dave,
I think the graph paper is a step up from the paper napkin that you were using. :wink: 8)
I get into trouble with crayons, keep going over the lines. :oops:
How did you do the "sketchy line style"?
Many thanks
Miles
I chose a line style under the Select tab in the Styles dialog box. In this case I used a commercially available line style but SketchUP comes with some as well.
