...The critical thing is to file every other one from one side and then turn it and do the others.
That is true for crosscut saws. For dovetailing, you are going with the grain, so rip cut is the better choice - and it is easier to file.
Yes to rip cut but you need to alternate sides to give the saw a trace of a set equal both ways, even if it's just a burr from the file. You can't otherwise set a 14tpi saw very easilyThat is true for crosscut saws. For dovetailing, you are going with the grain, so rip cut is the better choice - and it is easier to file.
Not sure. I'm more head down brain off! I'll have a look next time.Do you file slope into your gullets Jacob?
Some triangular files have rounded corners? I understood that saw files should have rounded corners as if they have sharp corners it can lead to cracks in the plate developing from the bottom of teeth.
