head clansman
hi dibs-h
Security for my workshop is always a constant worry to me. I started to day to improve my security , order one of those new hasp and staple type locks you see on vans nowadays the ones that cant be bolt cropped off .
My workshop door also opens out I'm going to cover door and frame protect hinges at same time with metal sheeting which i'm trying to sourcing today , once metal sheeting has arrived but before fitting the metal sheeting I have an old five point locking door lock from a double glazed front door that i will fit into edge of door and frame as well, might even get a second van lock , all windows will have vertical and horizontal interior flat metal bars fitted as well interwoven with each others.
My rear fence panels need replacing soon so they will be replaced with vertical shiplap fence probable about a foot higher 7ft and then lightly fitted trellis panel on top so if someone ties to climb over the trellis will collapse thus making noise .
I already have external garden lighting that i can switch on or off my self but i think this will need upgrading to come on low level light at dusk till dawn throwing light in the right places as a deterrent , and lastly an internal alarm which cannot be seen till it's to late .
hopefully enough to put off the local scrotes and maybe a real pro , luckily the workshop door can be seen from the house so i hope a well worded sign on the door will be enough to put him/her off as well .
hc
hc
