RobinBHM":bon2ns4d said:
I wouldnt use it for doors as I have tooling that will do scribe and tenon in one hit. However I can see it would be useful for doors or windows which have awkward shapes, ie raked heads or trangular windows - would a domino work for these?
Good question.
You can jig up a Domino and use it for mortices in angled components (there are two threaded holes in the sole plate which are useful for securing the Domnino to the jig), here's an example,
But you're
generally restricted to a mortice that's perpendicular to the face of the workpiece. That needs a bit of qualification, you can
sometimes make an angled mortice, but because the plunge depth is quite small compared with a mortice machine (even on the XL) you'll normally be fairly restricted with an angled mortice when using a Domino.
Compare the above set up with this one, a compound angled mortice on a chair leg using a morticer.
You can see it's much easier to set up this joint on a morticer (after all the clamping is built into the machine) the fixturing arrangement is easier to set up, I can tell you from practical experience that it's easier to achieve high levels of accuracy, and you have a significantly deeper plunge facility so can handle more extreme angles.
As I said earlier, I'm a big fan of the Domino and use both machines regularly, but once you go off-piste with your furniture making into areas like compound angles and mortices in shaped pieces, then you'll find a traditional mortice machine much more versatile.
Good luck!
