HappyThinker
New member
The domestic stainless steel cooker hood (600mm. slide out design) in my kitchen stopped working. I like it’s minimal look, more importantly is it's fitted to the kitchen units, also a better extraction performance is desired.
I am thinking of retain the whole casing with it’s filters. As the extract duct 120mm. is already attached from the casing to the external wall grille. I’ll remove the fan motor, leave the inside of the casing empty, remove the external wall grille, and connect the duct (extend a little with a bend) to an 125mm in-line fan mounted to the outside wall and discharge from there.
Will my system work? Will the fan be too powerful that will cause throbbing to the hood and the filters?
Thank you for reading my post.
