Doug B
Shy Tot
Personally I feel the problems with routers as with quite a few tools is folks use poorly designed tools & think they are all the same.
A well designed router will have dust extraction that works well built in & not some cheap plastic bolt on shute that appears to be an afterthought on the part of the manufacturer.
Most less expensive routers will be fixed speed so when ever you’re using it you it’s like a banshee squealing, a router with speed control allows you to slow the router down & it’s surprising how dialling the speed down just a touch reduces the noise considerably & makes no impact on the quality of cut.
Another problem mentioned here is difficulty changing cutters & most manufacturers have little imagination when designing their routers & simply copy a basic design which makes access to the collet fairly awkward thankfully some brands have addressed this making the collet far more accessible.
Obviously routers with this level of design aren’t cheap & when I started out I had an old 1/4” DeWalt single speed router that had all the problems mentioned in previous posts & it certainly wasn’t a joy to use, but not all routers are the same, some are a pleasure to use.
