RichardG
If at first you don’t succeed have a cup of tea.
I think I need a bowl gouge with a steeper angle as I always struggle to get a decent finish on the transition from the sides and onto the bottom of a bowl particularly when the sides are steep. I’m fairly certain it’s because I can’t keep the bevel rubbing using my current gouges which are ground to 45 degrees?
Do people generally have a specific gouge ground to say 60 degrees or higher just for this task? Currently I’m using scrapers to get the finish but the current bit of ash I’m turning has some odd grain which is proving hard to get a decent finish.
I’m loathed to regrind my current gouges and I wish I had a few older tools that I could experiment using different grinds to see what works before committing to buying something, what do others do?
