Its (more or less) fine on softwood, or, for instance, straight grained hardwood, but figured hardwood, even even stuff like oak with non-straight grain, and its not good.
Ive had the machine for some years, and been through various blades, set with care, and never had much luck with it.
With regards to "trueness and flatness", to me, that sounds like wood workers obsessiveness. Remember, its the thicknesser. One table that goes up and down. if its on the wonk, then the work will end up wedge shaped, which, unless you can say otherwise, is unrelated to tear out.
I guess if the table was vibrating or wobbling, then maybe that may affect things, but its not.
I know its a £1000 machine or whatever, but, to me, its pressed steel from china. I have modern Japanese CNC here, and old British cast also.
Really, my query is as to if there are machines that you can just feed figured wood through and not have to worry, or if a easier to use router sled is the answer, or maybe a drum sander.
