rafezetter
Troll Hunter
I was asked to make a display cubby, the ones with lots of spaces for various knick-knacks, but was otherwise given free range on the design.
I have a lot of slats of reclaimed cedar that used to be cladding on some dormer windows, so decided that would be a good use for some of it - I removed the paint with a heatgun then rough sanded it to get the reminder off (sorry no pics of that) - I was amazed at how little rot it had, only the T&G had any real signs of it. Once roughly cleaned I then measured and marked approx sections I'd need:
To thickness them all to the same dimensions I hotglued them to a makeshift sled and ran each batch through to 11mm, going down from 15mm in increments, then once all of them had been taken to 11mm, I ran each lot again to 10mm without moving the blade height, so they were all pretty much identical - the pine sections are to prevent thicknesser snipe - I should have left the lengths uncut and ran them whole, learned for next time :
I then collected all the bits and edge jointed them all at once, I used more pine blocks and screwed on a pine support rail (on the left) also jointed to 90deg to the base and sides to make sure they came out at 90 deg too, the finish was surprisingly good:
Once I'd cut the divider pieces to the lengths I needed on a friends ultra accurate and square mitre saw (no pics sorry), I then started the glueup. I did the bottom side first and used the actual main slats as the spacers:
Then glued up the top the same way:
Now I had the top and bottom with slats done, I used that to mark the side height accurately:
Now to the joints..... *deep breath*... My first ever attempt at box joints, many will say it's pretty stupid to not even make a few practise runs, and they are right, but I thought if I was slow and methodical I'd get where I wanted to be, and I was anxious to crack on... so I marked up:
Cut, then marked the second part:
And the result? Better than I had hoped; there is a bit of slop still, but if you look at the bottom shoulder you can see that they don't meet, a bit more cleanup and they went together as good as I could hope for:
3 more like that and I dry fit the frame using v handy 90deg clamps:
ran out of attachments....
Display Cubby 0-400.jpg22.1 KB
Display Cubby 1 - thiknessing-400.jpg15.6 KB
Display Cubby 2 - jointing-400.jpg14.3 KB
Display Cubby 3 Gluing Bottom-400.jpg18.1 KB
Display Cubby 4 - Gluing top-400.jpg17.7 KB
Display Cubby 5 - marking sides height-400.jpg21 KB
Display Cubby 6 - marking joints-400.jpg10.1 KB
Display Cubby 7 - joint pt 1 cut & marking pt 2-400.jpg10.4 KB
Display Cubby 8 - dry fit joint-400.jpg10 KB
Display Cubby 9 - Dry fit frame-400.jpg16.4 KB
