YorkshireMartin
I am probably pushing my luck as all I seem to do is bang on about issues with planer thicknessers....so, at the risk of outstaying my welcome..
After the debacle with the Axminster, I thought I'd go the whole hog and I managed to pick up a used Sedgwick PT255. I figured there wasn't much to go wrong with those. I found a used example from a dealer at a reasonable price. It turned up today and appeared as the vendor described. It's in pretty good nick overall.
The problem is, theres a dip in the outfeed table. I will have to borrow some feeler gauges to check how much of a dip there is, but it's enough that I can see daylight. I know my straight edge is perfectly straight and I verified it just to be sure.
The dip is along the width and is towards the front edge of the table but not across it's entirety. I'm thinking that someone was planing a lot of thinner stock and pulled the fence towards the front, the resulting friction from the thinner stock causing the dip, but surely this would take years? I doubt the machine is over 15 years old, it's in the newer sedgwick colours and the finish looks original.
This was described to me as a machine that had light use and indeed, visually I'd agree, aside from the issue above. I don't think it's been cosmetically restored.
How much of a dip should I tolerate? I don't want to cause a fuss if I'm close enough for it not to matter. I will be using this for traditional joinery though.
I'm not having much luck with planer/thicknessers at all!
Thanks again everyone, I promise I'll eventually start answering some questions, just as soon as I have some knowledge.
