Digitalizing My Thicknesser
SketchUp Guru
12 Apr 2005
Rochester, MN USA
A while back I bought a DeWalt DW735 Thicknesser to replace my Ridgid planer. I had the Wixey WR500 on the Ridgid and wanted to install it on the DeWalt. The Wixey solution is to use foam tape to attach the unit to the analog scale. I didn't like that idea so much so I went at it a little differently.
I asked a machinist friend to make a replacement for the analog scale bracket. He went above and beyond by making it out of stainless steel and adding slots so the Wixey bracket can be easily adjusted for the height of the bed. He even buffed it up so it looks nice. It works perfectly and will be easy to reverse if I ever sell this planer and want to keep the DRO.
Here are a few pictures.
As with the original, there's little clearance behind the bracket. On the original they crowned it a little. This bracket is flat. I used 10-32x1/4 machine screws and oval nuts to attach the WR500 to the new bracket.
Gidon,
I didn't think it was possible to fit these to a planer/thicknesser owing to the design. A couple of photos would be appreciated.
Nice job Dave by the way.
Alan
Woody Alan":2zg776me said:
Gidon,
Alan
Alan
Here you go:
Attached to my Scheppach HMS260:
Frame is attached to some alu angle iron and a hole is tapped in the rod that attaches to the original pointer:
In the end I tapped some holes to attach the readout (stationary). Make sure the bolts don't come through the other side (they'll interfere with the rise and fall - believe me ;)!)
Close-up of the frame of the digital readout attached to the alu angle iron:
More info in these two threads:
https://www.ukworkshop.co.uk/forums/view ... hp?t=12408
https://www.ukworkshop.co.uk/forums/view ... hp?t=12493
Gidon
