I’ve just aquired a Sorby Pro Edge ,I’m familiarising myself with the system,I’m practicing sharpening a ovss as l skew chisel (oval skew) ,I put my diamond belt on ,just to see how the edge will be,I set it at 15 degrees,the problem is,because the Diamond Belt is thick ,when I switch the machine on,it sticks and won’t rotate,Will I have to chamfer the back edge of the plate,?Or I’m doing something not right?
