Dial Caliper
custard
20 Aug 2008
Hampshire
I just got a new metric dial caliper to replace my old vernier imperial caliper, I can't recall the name but it's a decent brand. It arrived with no instructions and when I close it the dial reads about 0.04mm rather than zero.
Couple of questions,
1. Is it a pup?
2. If not, how to adjust?
3. Underneath the dial there's a knob, but the function isn't immediately apparent, any suggestions?
The knob could be a lock as you usually move the scale to bring the reading to zero (rotate the housing)then fix with lock knob
Thanks Old, that's sorted it!
Incidentally, I like the look of the garden bench in your avatar. Are plans available for it?
