sunnybob":3lrm6v4o said:Soft sanding pads are only good for curved surfaces.
Use one on a flat piece of wood and you will round the edges over without even realising it.
Agreed, 120g is way too aggressive. I have a special little box just for 600g Abranet that I use solely for de-nibbing and the more each piece is used, the better it becomes. All that's needed is a swift, very light wipe of abrasive (wrapped round a cork block if needed) to take off any dust particles from the finish. Then feel it with your finger tips to see if its smooth, vacuum off any dust and then apply the next coat. A decent sized desk top should take no longer than 5-7 seconds to de-nib; if it takes longer than that you're giving it too much grief! - RobAES":3282ldzb said:I guess it depends on the job and the finish, but IMO anyway, 120 would be much too coarse. For de-nibbing, I'd be starting at 600 and going even finer (next go a piece of well-used 60, last one, probably 1000, or 4x0 wire wool). It's all about FINE and GENTLY (well that's my experience anyway). NO elbow grease needed here!
It's easier to use a block of some sort as you get better contact on flat surfaces (my blocks are bits of carpet tile stuck to ply offcuts). All you are trying to do is remove the tiniest bits of dirt and dust - if it takes more than a quick wipe, you've done something wrong - either you've not done your preparation properly or you've polished in a dusty atmosphere (made worse if the polish is slow drying as it'll pick up even more). I suspect you're trying to get rid of something that shouldn't have been there in the first place. If your polish (of whatever description) has raised the grain you should have dealt with that before you got to the denibbing stage - a sanding sealer, a very dilute first coat of polish or even a wipe over with (hot) water will raise the grain for sanding before starting to polish.morpheus83uk":2dm98gby said:Brilliant. So by the sounds of it I wouldn't need the block then just a very gentle wipe over with the Abranet by hand and its done. I presume I could use them on the curves too or would I still need the soft sanding pads?
James
