I'm going to be making replacement windows for my house, they will be flush fitting and made from Utile. 24mm glazing units on Ebay seem to be best price and a good quality they are also within reasonable, " free " collection distance.
The 24mm glazing units when placed in the sash will make everything quite a bit thicker. The whole lot will have to fit flush into a suitable sized rebate.
I read the posts on this forum about using the tablesaw to cut non through cuts. My riving knife is higher than the saw blade, so reading through the posts etc and considering, I think the table saw method for me, is a non starter.
I then looked at the Whitehill Combihead Scribe and Rebate Block on Axminster http://www.axminster.co.uk/whitehill-co ... k-ax823688
The block is Recessed for flush mounting with a countersunk screw allowing material to be passed above the cutter block.
Axminster told me I could cut a 100mm deep rebate with this block. Says it can use 40mm and 50mm knives but Axminster only list 40mm rebating knives.
When I was mulling this all over, frying my brain, trying to make sense of all this
I'm thinking, say a 60mm rebate in the frame seems awfully big to me I also thought taking out such a deep rebate might impact on the structural stability of the timber?
In the past I've had a look at the timber windows on Ebay to try to get an idea of how they were put together. I looked this evening, only looked at one so far, ( all this one finger typing takes ages, dictation software a no go, buck teeth, can't you speak properly, incoherent or what he is using 24mm glazing units and says, " Slimline frame, our casement frame is only 88mm " Looking at his section view see attached, his method of jointing seems a lot more complicated than how I'm thinking of doing it, he has an equivalent rebate area depth of about 60mm.
So such a deep rebate isn't as impractical as I was beginning to think. If I were to use the Whitehill combi head,I think I can use a false fence to allow me to get a 60mm rebate. Though 60mm of cutters knives is quite a lot exposed, that said I will be using my huge 1 hp power feed.
I think I would have to push the fence and shroud quite a way back to get the 60mm. I might not be able to move that far back, because of the powerfeed mount bolted into a steel plate I had made up so could fit the mount into the plate then bolt the plate into the table. I think the fence and shroud will be prevented going that far back because of the plate, that said I think I can repostion the plate to get around that.
Also the bottom of the shroud goes over the back of the table, several inches open underneath, don't think this will be too great for dust and chip extraction?
Lastly the Axminster combihead is £180, Whitehill do a 125 x 80 x 30b 4wg Shear Ally Rebate Head for £228 and also a 125 x 100 x 30b 4wg Ally Rebate Head for £236 both ex vat and delivery.
On his post showing how he made his window, Coley used an 80 or a 100 rebate with a tilting spindle to make his 9 degree window cill.
If I have a mate machine a recess into the Whitehill 125 x 80 x 30 head so I can fix it to the spindle with a countersunk screw.
Then I could use the Whitehill 125 x 80 x 30 or the Whitehill 125 x 100 x 30 to machine both the frame rebate and the cill. I think I might get better results doing the cill this way than using an angled sled on the thicknesser part of my Metabo 260 planer thicknesser
I had thought of doing the rebates on my Metabo 260 planer, thicknesser?
I don't know if I'm on the right page with all this, as ever, any help and advice much appreciated. I have Axminster WS1000TA spindle moulder which has a 100mm spindle and I believe has a spindle movement up,down of a 100mm.
Thanks guys.
Thanks guys.
