Decking project advice
sphannaby
New member
23 Apr 2017
Durham
Hi,
New to the forum. I joined after I was looking at some tips and came across the site, hoping some of the experts can offer some pointers and advice.
Just to give you some background I have attached some basic sketches of what I currently have and what I plan to achieve.
In attachment labelled 'As is' I have tried to represent the current state of our garden. The slopes are not exact but they give a fairly good idea of how it is.
Attachment 'New Garden' shows our plan of how we want it when finished. The decking area is 6.5m wide and 7.5 long.
I had planned on outsourcing all of the work but funds have dried up a little so I am looking to take it on myself now.
The right hand side of the garden as you look at it is definitely going to be levelled off for turf to go on. Plan was to have a retaining wall at the top end and to right hand side as required, this will be built by my father in law who is a brickie.
One of the issues causing me a headache is the land which the decking will go on. When we had people round to quote they said they would simple take out of the top section of the decking base area and put in in the bottom to level it out and this would mean there would be no waste from that section. I was happy enough with that but my father in law informed me that this would then create a different height step between the levelled turf area and this new decking base area. He stated this would also need to be retained somehow. When I asked the lads who quoted the job they stated pieces of 3' x 2' would be used to retain this. My father in law reckons that wouldn't be good enough and a proper retaining wall would be needed.
So my next thought was to take the decking base area down level to the same level as the turfed area and build the decking up from there. This would require another retain wall but that would be around the perimeter of the area rather than hidden underneath the decking. I feel this would look neater and also allow for greater flexibility in later years should we ever decide to get rid of the decking.
My main question is if I level the decking base area down the same as the rest of the garden this will give me a height difference of 500mm from base to my desired finished deck height. Is this a suitable sort of height to be able to build up to using a bearer and joist decking frame?
Once I know that I can get my head round things a little better.
I have done a bit research but had a few other questions hoping others can help with:
1 = Am I correct in thinking I should have bearers down first and these should be attached to steel supports which are concreted into the sub base? If so does anyone have any recommendations for supports to use?
2 = How would I go about calculating what size bearers and joists to use?
3 = I read that decking should have a 40:1 incline ratio to prevent water pooling. Am I correct in thinking this should be achieved by putting the incline direct at the bearers rather than packing the deck boards?
4 = Because the length is 7.5m I guess I will struggle to get single length of deck boards. Would I be better cutting boards to 3.75 so I have a uniform joint line down the middle or is it better to stagger the joints for more stability (for example as you would with laminate flooring)?
5 = With regards to the full length steps the Mrs has stated she would like wide steps, say 2 or 3 full boards (I have done my sketch based on 2 boards). From what I have been able to find on the internet I can't seem to find any pre-made stringers that would accommodate this. Am i just looking in the wrong places or are these generally no available for wider steps (total make up height of steps will be 500mm)?
Any response to this would be greatly appreciated and I'm sure I will have a few more questions later!
    90 KB
    95.3 KB
Hi welcome to the forum :D
Just in case you didnt know, decking more than 300mm above ground level needs planning permission. Yours is not very high above ground level, so probably not worth worrying about unless you have really troublesome neighbours.
I think raised decks are often done with vertical 4 x 4 posts concreted in, then joisted out.
I know some guys that do decks and theyve learnt to build the whole frame on the lawn, dig the post holes then carry it to position, level up and concrete in. That can only work if you have plenty of bodies on site, but you could do a similar thi g in sections. It saves spending ages positioning all the posts to line up and be at correct height. A laser level would be a great help to set your datum.
Timber posts last longer if they are wrapped in bitumin flash band below concrete line. There is a company that now makes post boots just for that purpose.
