MarkDennehy
Thing to remember is that that test is entirely dependent on the flat edge you reference against being actually flat.transatlantic":153uh8et said:Is that really going to be any better than the draw a line (with a mechanical pencil or even better a knife) and flip over test? I don't think so.
And you made that edge with a plane.
So the tolerance in the square can't ever exceed the tolerance to which you work with the plane; and since that's probably your most accurate tool, that's grand for practical purposes.
You get a certified square, they'll have dialled that in with a dial indicator to waaaay beyond the accuracy of your plane so the answer will be better, but you won't be able to work to that accuracy anyway so it's an academic benefit at most really.
It's when you cannot measure as or more accurately than you work that the problems arise...
