mpooley
Re-sizing Method 1
With the Tape Measure (T), select an edge of the object you want to be a precise dimension, and then enter the new dimension you want for this edge. The object will be scaled to that precise dimension.
If the object is a component only the component will be re-scaled. If it's not a component, this will re-scale everything in the drawing
Dave I cant get this to work what am i doing wrong?
i made a rectangle pulled it into a solid made it a component and then using tape clicked onto a edge and typed in a new dimension - tried several variation but nothing happened.
Mike
Mike
