Dakota Tormek Rip Off
wizer
3 Mar 2005
I'll pass
http://www.rutlands.co.uk/cgi-bin/psPro ... i?promo=61
I can only assume that whatever protection Tormek have had on their design must have expired
Knock offs are also sold by Scheppach and Jet but I understand that Tormek still have the widest range of jigs available.
Bob
Missed Dakota-bashing, Wizer...? :wink: I think you lasted a good few weeks without mention of them :lol:
I don't know. The deign is pretty straight forward. Maybe, like the green clamps, these are 'made in the same factory'. But for it to be so drastically cheaper than the real thing, can only mean cheaper parts? I wouldn't risk my money. If I was going to go for a cheaper option of the Tormek it'd be the Jet or Sheppach. 2 brands you can trust.
I wouldn't know, but I'd imagine that if I was going to spend that much on a sharpening system, there are too many questions around the quality of Dakota, and the service of Rutlands.... I'd go with something else myself.
Speaking of Dakota, does anybody have their vacuum press?
I may need a vacuum press in the near future, and was wandering would the Dakota machine be up to the task of laminating a curved back chair.
The dakota machine is less that £200 whereas a Bagpress is over £500, there's probably a reason for that though.:roll: :roll:
Aled
Aled,
If you are only likely to need a press for the one job, then maybe a homebrew scheme using an "under the bed" vacuum storage bag as sold by the ALDIs and LIDLs stores from time to time plus and old fridge compressor, pipe and car tyre valves would be suitable.
To avoid the compressor overheating, use a cheapo plug in timeswitch to run it for a period and then give it a break and so on until the glue goes off.
Each time you use the compressor give it a couple of squirts of car engine oil down the air intake as otherwise it will eventually run out of oil and seize up.
Just a thought
Bob
9fingers":272r3g1c said:
Aled,
Just a thought
Bob
Thanks Bob. If the project comes off, I'm going to need quite a big bag, but the fridge copmressor idea sound good. Do you have any info as regards converting the compressor, or is it just a case of venting the refrigerant (legally of course) and connecting up a bag to the inlet end.
Aled
Aled
I've got the Airpress which is excellent but at the price they charge, it should be...mind you, they make them just up the road so a personal visitation secured a bit of discount :wink: They're also excellent for after sales and technical help, though their bags are crap :x
As for the Dakota thing...'caveat emptor' (sp?) - Rob
Aled Dafis":l0v04rja said:
9fingers":l0v04rja said:
Aled,
Just a though to
Bob
Thanks Bob. If the project comes off, I'm going to need quite a big bag, but the fridge compressor idea sound good. Do you have any info as regards converting the compressor, or is it just a case of venting the refrigerant (legally of course) and connecting up a bag to the inlet end.
Aled
That is about it. Cut the pipes leaving as much length on the compressor as poss. Have the outlet vertical to minimise the oil getting chucked out. Perhaps bind a bundle of rag round it?
Cut the pipe with a wheeled pipe cutter to prevent metal swarf entering the compressor works.
I think you can buy heavy gauge polythene 'flat' tube for bags.
Bob
Oh, really?
I have the Sheppach Tiger and, as I have written several times, I am not impressed.
Dave
I've made many purchases from Rutlands and have always been perfectly happy with their service.
Dave
I'd not seen that Dave. In which case, the Dakota one must be diabolical. I think DaveL is happy with his Jet.
Well I've got the real thing (Tormek) and don't think its that earth shatteringly great. I think it is a tool that is underwhelming even when its a good one.
Ed
I've used the Tormek and own the Sheppach, I only visit it when I have to grind all the way back as getting it set up just right is a real pig. Can't believe they all use cheap welded round bar with individually adjustable legs, trying to get it square is the big issue.
There must be a better way - perhaps a Kreg add on....
Dave
I've had issues..... I think the consensus tends to be that if everything goes as planned with the initial purchase, you're ok. If, however, you need some after-sales support they can be....um.....less helpful. That said, I've not heard any complaints on here in a while. Maybe things are changing...
Bob - previous career as a creative consultant for MacGuyver...? :lol:
Had to go rushing back out to the garage after reading that, but it was ok, they were still holding things together. :shock:
Regards, John
