Same thing I suggested... am I missing something here? Sorry, I've not slept well lately, so I'm clearly not understanding.
Sounds a good idea. Just awaiting my router bit from Ebay. It can only be 12mm high for this. All mine are too long. Thanks for the reply.Maybe use use a combination of mitre saw and router table?
You could put a few cuts in with the mitre saw which would allow you to remove the bulk of it with a chisel then just use the router table to clean up the bottom of the joint.
I might be wrong, but I think Triton was poking fun at the vastly inferior Veritas router plane over the Lie Nielsen router plane (both are very good).Same thing I suggested... am I missing something here? Sorry, I've not slept well lately, so I'm clearly not understanding.
Yours was a Veritas, i countered with a Lie Nielsen.Same thing I suggested... am I missing something here? Sorry, I've not slept well lately, so I'm clearly not understanding.
Hah, okay, I totally missed thatYours was a Veritas, i countered with a Lie Nielsen.
But as above, both are very good. Just bit of fun on my part.
Are you not using a plunge router ?Just awaiting my router bit from Ebay. It can only be 12mm high for this. All mine are too long. Thanks for the reply.
Thank you for the reply. My plunge router is permanently set into a router table. Never to see the light of day again! Trouble is with my recent project I need to go to a certain depth with the guide bearing datum reaching an edge. My router is too big for me to hand hold. I must invest in a palm router so I have both options without swapping and changing from the table. The table height adjustment is not really a problem for me as this can be adjusted from the top winder. I have made notes of your advice on multiple passes. Being a novice I learn something new every day on here.Are you not using a plunge router ?
Longer bits are no problem. You set the depth stop and only plunge as deep as needed.
Just in case, let me also point out that a router is infinitely more controllable if you don't try and cut full depth in one pass. Multiple passes plunging a few mm more each time will quickly remove the bulk and work down to full depth. When you get the hang of it you don't even lock the plunge, just ease it down as you sweep from one end of a cut to the other. Lock off for the bottoming cut. Reset back to say 3mm depth and start the next set of cuts working back towards the shoulders.
I've watched many inexperienced users make a horrid mess thinking they could cut the entire moulding in one pass. Occasionally you can but it's often not a good idea.
This is a disadvantage of router tables. Height adjustment is awkward compared to the ease of plunging a handheld so folk often can't be bothered taking multiple passes.
Thanks for the feedback. Understanding more of your setup helps. If you're using a bearing giuded bit (they are good) rather than a plain bit and guide bush, it makes sense.Thank you for the reply. My plunge router is permanently set into a router table. Never to see the light of day again! Trouble is with my recent project I need to go to a certain depth with the guide bearing datum reaching an edge. My router is too big for me to hand hold. I must invest in a palm router so I have both options without swapping and changing from the table. The table height adjustment is not really a problem for me as this can be adjusted from the top winder. I have made notes of your advice on multiple passes. Being a novice I learn something new every day on here.
For cutting cross halving joints on larger scale pieces, I generally prefer taking a hand held router and cross cutting jig to the wood rather than taking the wood to a router table. Your 30" long dimension, to me, places your wood into the borderline 'larger scale' category, but even so I'd still probably take a hand held router to the wood rather than than pass the wood over a table mounted router.So I have two pieces of 30" long 4x1. I want to cut a half depth dado groove across the middle so as to make a cross. I normally mark them out and use a mitre saw set to depth then do multiple cuts to get the 4" width right. This is such a tedious task and the bottom of the dado is lined with saw cuts. I was wondering if it could be done easier somehow on my router table ( not freehand ). Perhaps with some sort of jig to make it easier and the bottom of the groove should also be a lot flatter.
John.
That's certainly true, particularly for executing a single joint for a project, e.g., a cross halving, and doing the job by hand for even a few doesn't take long. I should perhaps have mentioned that in my post above, although if a jig or guide is to hand already it's another option, particularly if there are many joints to do, such as cross halvings, housings, trenches and can even come in to cut multiple tenons. Slainte.Look up Half Lap Joint, it’s a basic joint easily done with hand tools.
Thanks for the reply. Yes I do quite a few of them.I have to agree with the above. It can be done and dusted with hand tools by the time it takes to set up some kind of router jig. If you were doing a whole heap of them then by all means use machines to save time.
John
Thanks Sgian. I do quite a few so I needed to speed up the process a little.That's certainly true, particularly for executing a single joint for a project, e.g., a cross, and doing the job by hand for even a few doesn't take long. I should perhaps have mentioned that in my post above, although if a jig or guide is to hand already it's another option, particularly if there are many joints to do, such as cross halvings, housings, trenches and can even come in to cut multiple tenons. Slainte.
Thanks hlvd. I do quite a few so I needed to speed up the process a little.Look up Half Lap Joint, it’s a basic joint easily done with hand tools.
Wow Richard thank you for your reply, my projects are not on your scale!! By your images you are an absolute craftsman. I will certainly take something from your post.For cutting cross halving joints on larger scale pieces, I generally prefer taking a hand held router and cross cutting jig to the wood rather than taking the wood to a router table. Your 30" long dimension, to me, places your wood into the borderline 'larger scale' category, but even so I'd still probably take a hand held router to the wood rather than than pass the wood over a table mounted router.
Whilst I appreciate the task illustrated below isn't the same as you're doing, the images should give you the general idea of the sort of jig you might make along with the router type. Slainte.
PS. On a side note, what you're calling a dado is more commonly known on the eastern side of the Atlantic as a trench, if wide, or a housing, if narrow.
Did that Doug, seemed to work a treat! Still looking to get away from the mitre saw. If not I will stick to this method.Maybe use use a combination of mitre saw and router table?
