andrewm
I have a series of architraves to fit to doors that are not at exactly 90 degrees. Hence I am going to have to cut the mitres at an angle which is slightly off 45 degrees.
My LS1013 SCMS will do this but has defined stops at some angles including 45 so if I try to set it to say, 44.5 degrees it jumps to the 45 degree setting. I am impressed at how accurate this 45 degree setting is but for this application it is not what I need. Has anyone come across this problem or found a way around it?
Andrew
Andrew
