Alf
In another thread far, far away, Chris asked the question I hoped nobody would:
You see I have a dark secret that I've been loathed to confess even to close friends. Perhaps some will have guessed already - a hardened neanderthal owning a Woodrat is a bit of a giveaway after all. You see, I can't do hand cut dovetails. There, I've said it at last. Better out than in. I've tried again and again, and it's always the chiselling out of the waste that lets me down every time (latterly anyway; before that it was the sawing of the waste, before that the initial cuts, and prior to that the marking out... :roll: ). The results have been to hideous to imagine. Oh, the shame. Periodically the guilt overcomes me and I go into the workshop and have another go. Firewood is the inevitable result.
So my friends, imagine my delight when, after nearly 45 mins of careful, plodding, concentrated work with saws and Japanese chisel on just one joint in 12mm oak, I ended up with this:
It's not glued, merely a wipe of shellac to bring out the contrast. No shims, filler or chunks of wood to fill in the gaps, no, not one. :shock: They're not perfect, and they're not spectacular, but at last I feel like I might stand a chance of actually being able to cut honest-to-goodness hand cut dovetails now. For real. When it matters.
Don't you just love it when a plan comes together? (tm The A Team)
Cheers, Alf
Immediately I cursed my foolishness in mentioning the dovetail wotsit at all. Blabbermouth that I am. :roll:waterhead37":r4cyf9ey said:A good first step - now we want to see the dovetails you cut with the aid of your marking wotsits!
Cheers, Alf
