(To me) does not make sense using a router on larger circles. YMMV.Why not use a router and a tramel, could just be a length of wood that you have a 20 or 30mm hole in one end to sit the router bush in and a pivot at the required radius at the other end.
Subtle @Droogs !The reason the guy in the first video has to go round twice and ends up with a second small sliver of wood is he has not correctly aligned the pin. He has his jig set up so that the OD face of the pin is in line with the front cutting edge of the blade instead of the centre of the pin itself. This leads to a slightly oval cut as the piece is rotated and causes a slight spiral as he turns the piece while being cut. With his method you will always have slightly undersized finished parts
Oddly, I (guessed) thought a square top to a lazy susan would be more useful... commercial bearings Jon ;-)I did my 18" lasy Susan on my lathe. That makes it round
Oh, nearly forgot to say that I also turned all 36 of the ⅝" balls on the lathe too, good fun
