Hello!
I need to make some steel straps for a timber house restoration. Some are straight, some will have a right angle bend in them.
I know a little abt metalworking but don't have a lot of equipment. For hole making I have a heavy drill press so that is covered. For cutting I have an angle grinder and a jigsaw and after watching a youtube abt cutting sheet steel I think the jigsaw with the right sort of blade seems to be a reasonable choice. I do own a Hammer woodworking bandsaw but I'm not sure it it would cope with steel. It might even say alu is ok but steel not, if memory serves. I will check on this, but it might not be an option for me right now anyway since my Hammer is three phase and I've moved to a single phase property and have yet to purchase an inverter. I did mention I'm on a budget.
For bending I wonder what people do without expensive equipment or a forge? Is it possible to heat certain steels with say a plumbers mapp gas blowtorch and hammer it over in a vice? What type of steels would be best to use? Does the steel have to be hot to bend or can it be done cold with some kind of lever - I imagine that is not generally possible without heavy machinery?
My motivation here is cost. I had two lots of two straps made which needed to be stainless as they were going to be installed externally and they came out at around £180 and £300 for the two pairs. The seven or so remaining straps are internal only so I'm happy to use bog standard mild steel, for example. I thought it might be quite a nice job that i could tackle myself.
The dimensions and shapes vary but all are 6mm thick and 40mm wide. I could probably make all the straps from a 1/2 meter square sheet.
What type of steel should I use and what are cheap sources? Do people use gumtree or ebay to buy metals?
Thank you,
Woodspiral
Thank you,
Woodspiral
