RogerS
I had a SU drawing of a casement window and resized it using the Scale tool. However, when I ran CutList, the results still reflected the original size. By a bit of fiddling, I found Scale Definition and selecting each component and then applying Scale Definition (whatever that is) CutList picked up the correct size. Selecting the whole model didn't give the Scale Definition option and so I had to laboriously select each component in turn....a very long-winded and far from ideal solution plus you are left with the nagging sense that you might have missed one. So you end up double-checking which kind of defeats the object.
So...my approach using Scale Definition. Is that the best way?
EDIT: OK..I see that Scale definition applies any scaling to the Component definition in the Component Browser and since that is what drives CutList then that makes sense. So we're looking for a better way to apply Scale Definition.
